I want to join 4 mpeg1 files together (all have same parameters). I tried to use VirtualDubMod but the append function is greyed out (see screenshot). Is there any freeware solution to join these mpeg1 files without any quality loss? I tried Video Redo and it seems to work but I want a freeware solution.
OK, I need help with the geeky software. When I tried to use TMPGEnc Mpeg tools (see screenshot 1) , I joined them but there was no audio. How can I join them with TMPGEnc and also have the audio/video together (that's what most people want).
Then I tried Avidemux. That seemed to work OK, but I don't know what to choose (see screenshot 2) in the FORMAT box. Should I choose MPEG-PS (A+V) or should I choose MPEG-TS (A+V)? What is the difference? I tried both of them and they both worked, but the MPEG-PS gave a joined file size of 253MB and the MPEG-TS gave a joined file size of 261MB. Why is there a difference in file size? Both joined video clips have the same time length.
My fault. The files don't need to be joined. Each file (after de-multiplexing into video/audio) just needs to be put in Gui For DVD Author as separate titles.
Make sure that the audio is sampled at 48000 for DVD authoring.Originally Posted by jimdagys
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
Simple question....... what is the best way to join AVI files
By True Colors in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2010, 21:22 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 07:21 -
question about how to author DVD from several mpeg1 files
By jimdagys in forum Newbie / General discussionsReplies: 11Last Post: 5th Jan 2008, 07:49 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
