I need to take out the last view vertical lines of an AVI and replace with black when frameserving to CCE using VDub. I did not see an option for this in teh filters...how do I do this?
Heya.
It's in the Resize Filter. Add the resize filter, then you should see Cropping in the filter window.
Chris -
I see what your talking about, teh expand frame and letterbox" part. I cant figure out how do get it to do what I want though. I need to replace the last 10 lines from teh bottom of a 720x480 image. When I capture I get some sort of weird staitc on the bottom and would like to replace the with black. When I use TMPG I simply use its cropping ability, is it possible to do it with and VDub? What settings would I need? I dont mind if I have to cut the same amount off the top but would prefer not to
Thanks :P -
Fairly simple:
- Open Video menu, select Filters
- Click the Add button
- Double-click on "null transform"
- Click the Cropping button (near the bottom) and there ya go. -
There it is...amazing what you don't see when your not looking for it!
Thanks very much!!
Need to crop a time stamp out of AVI file
By katD in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2010, 10:55 -
Simple CROP of AVI (XVID) in virtualdubmod
By Rudyard in forum EditingReplies: 4Last Post: 1st Jun 2010, 20:43 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24
