hi!
I got a .avi file with framerates : 23.976 (NTSC avi) which I want to convert to .m2v. But when I input my .avs file into HCEnc I got an ERROR message in the bottom panel where it's written :
and now if I check in the 3:2 pulldown radio button I got a new message:Code:use pulldown for DVD compilance, WARNING, resolution/frame rate mismatch
and if I instead of checking the 3:2 pulldown button press "make DVD compilant" button I got a different error message instead:Code:pulldown turned on, set flags for 23.976 --> 29.97 fps, interlaced is disabled, if your score is interlaced please de-interlence it first, if input rate is not equal to 23.976, setting is ignored.
I made my .avs file in FitCD in NTSC settings:Code:possible non-DVD compilant settings fixed, WARNING, resolution NOT DVD-COMPILANT, WARNING, resolution/frame rate mismatch
I didn't check the PAL button and my Destination is set to : 704x480
If I don't care about this warnings and create my MPEG file and then try to make a DVD in GfD with that file I got an error while creating it:
Code:Rejected sp r/fr 1.m2v
here is more info about my .avi file:
from GSpot:
Code:AUDIO: Codec: 0x0055 MPEG-1 Layer 3 Info: 48000Hz 116 kb/s tot , Joint Stereo VIDEO: Codec: XVID Name: XviD Dev ver. 11-Jun-03 Pic/s: 23.976 Frames/s: 23.976 pic (w h) : 624 x 464
please help!
glad for answers!
michcio
Results 1 to 9 of 9
Thank you for the GSpot info as that info is handy but can you also post your AviSynth AVS script as well because without that it is hard to say exactly what is wrong.
The only thing that I can think of as of now is that I always do 720x480 or 720x576 but never 704x480 nor 704x576 and although both 720 and 704 are DVD compliant it could be that HCenc only likes 720 and not 704.
This is only a guess based on the limited information available to me and the fact that I always use a width of 720 when using HCenc and have never encountered the type of errors you are currently getting.
So go back and create a new AViSynth AVS script with FitCD but use 720 as your width and see how that works or use your existing script but add 8 pixels of black to either side (with the AddBorders() command) to make it 720.
thank you for answering so fast FulciLives and jagabo!! =)Originally Posted by FulciLives
ah I change the width to 720 instead of 704 and the DVD type to 740 also (instead of DVD702 I choose DVD740) and then HCEnc opened my .avs without any errors
..thanks for that tip FulicLives!!
and here is now my new .avs file:
and here is the old .avs that gave me my error:Code:# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =- AVISource("MyFile.avi") BicubicResize(720,480,0,0.6,0,4,624,456) #Trim(0,64986).FadeOut(150)
Code:# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =- AVISource("MyFile.avi") BicubicResize(704,480,0,0.6,2,0,620,464) #Trim(0,64986).FadeOut(150)
hm I have as well always been abel to encode this kind of files without any problems in HCEnc...for example the "old .avs code" I use for this file while used on a simular one don't give me any errors at all :S that's really weird. Where do you set the frame type to progressive in HCEnc?Originally Posted by jagabo
once again thank you for good response
michcio
P.S. I'll soon test to create a DVD in GfD and see if my new .m2v file works =) -
Seetings 1 tab, top left. It's set automatically (for a 23.976 fps source) when you press the Make DVD Compliant button on the Main tab.Originally Posted by michcio
ah ok yeah I can see that it' set to progressive there...btw I have now made a new project in GfD with my .m2v (from the new .avs) and it work just fine! So my problem is solved I think!!Originally Posted by jagabo
THANKS FOR ALL YOUR HELP!
cheers
michcio -
Seems strange ... one says 704 width doesn't work and the other says it does work.
What version(s) are you two using? The newest? The newest version is v0.23 and I've used it a few times now and I wonder if this version just isn't "screwy" somehow?
For instance I never had this problem before but when using v0.23 the M2V will not load into TMGEnc DVD Author but this is only some of the time. Other times it loads A-OK. When it won't load the only thing that "fixes" the problem is to author with MUXMAN then import the MUXMAN output into TMPGEnc DVD Author and BINGO it works. Yet I never had such an issue with the older versions including the v0.22 version.
Weird !?!?!?!
I might just go back to v0.22
yeah that's really weird
well I'm using v. 0.23 as well and I had never have any trubbles on vers. 0.22...
maybe it's like you say that 0.23 got some bugg.
(HCenc) WARNING, small source mismatch found in pass 2, ...
By KKPHM in forum Authoring (DVD)Replies: 13Last Post: 19th Dec 2015, 08:37 -
HCEnc vs MVBR
By awesomer in forum Video ConversionReplies: 7Last Post: 31st Jul 2008, 18:12 -
DVD Audio format mismatch?
By Scally in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 08:07 -
audio video mismatch
By sumeshkri in forum Software PlayingReplies: 1Last Post: 31st Dec 2007, 11:00 -
HCEnc
By Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 09:57
