Hello everyone. I'm having some very sporadic playback issues with playing different burned DVDs on my DVD player. First, let me tell you a few details. My DVD player is a Philips, model DVP642/37. I use Memorex 16X DVD-Rs. I burn all of my video DVDs to Data form.
At first, I was thinking it was the file TYPE (avi, mpg, mov, etc) that was being subjective with the DVD player. But it's so hard to believe that for a few reasons. For one, some movies will play if they're MOV format, while other MOV movies will not. Second, most of the time the DVD player will tell me "Codec Not Supported" when it refuses playback.
I tried to convert all my movie formats to (MOV) because I'm currently watching a series of videos that are all in MOV format, and they're playing just fine. Then, I decided to test even bigger by converting one file to several formats (making different files) and seeing what ones would and would not play. I used a converter I have purchased called Magic Video Converter to do this with. So, I took some MP4 files and converted them to MOV, AVI, MPEG, WMV, RM, and even SWF. I then burned them to a DVD, like normal, and tried playing them. Not even one file would play, and only two even showed up in the main menu.
After looking carefully, I see that I can select a few different Video and Audio codecs for conversion. They are:
Video-----
Svq1
Divx
Xvid
H263
H264
Audio-----
AAC
A-Law
AMR Normal-Band
WAV (pcm 16 little-endian)
WAV (pcm 16 big-endian)
I'm looking for any and all advice on what I need to do to burn DVDs and play them on my DVD player. I have several movies of varying formats that I want to burn and watch, from FLV to MOV to AVI; lots of format types. What do I need to do? What codecs should I use when converting? What file types will and will not play? Please, any and all help would be greatly appreciated. Thank you for your time.
~ Vincent
ps:
Also, if anything, I would greatly appreciate suggestions for DVD players that are good at playing back various formats/codec types. Basically, the best DVD player for burned DVD-Rs.
Another DVDs Freeze during Playback on stand alone DVD Player thread
By bpatters69 in forum Authoring (DVD)Replies: 9Last Post: 23rd Nov 2009, 11:46 -
Problem With Stand alone DVD player and Burned Dvds
By tealmarlin in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2009, 15:02 -
Windows media player 11 playback codec for DV AVI
By Canadian* in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 27th Mar 2008, 18:56 -
DVDs burned in Samsung DVD Writer only possible to watch in some DVD Player
By jorgepe in forum DVD & Blu-ray WritersReplies: 9Last Post: 4th Jan 2008, 04:15 -
Burned dvds choppy towards end on TV Dvd player
By bendit in forum Authoring (DVD)Replies: 1Last Post: 14th Jun 2007, 15:55
