I have made a video with Tegrity for teaching a class. Unfortunately the audio was recorded too low.
There are several asf files, and i found one that is audio only. I want to amplify the audio in this asf file, but have not been able to find a solution.
Not very easy because it's an ASF file and they're more painful to edit.
The basic steps are:
Convert ASF to WAV
Apply Gain/Normalization to WAV
Convert WAV to ASF -
Thanks for the help.
I was able to convert to a wave using mplayer as described in https://forum.videohelp.com/topic281724.html
I used Ubuntu, so I just typed sudo apt-get install mplayer instead of downloading from the site.
I'm using Audacity now, and I see that I can adjust the gain easily, but I'm trying to reduce the noise now.
I guess I should just try different settings, until I'm satisfied with the quality.
Hopefully mplayer will convert back from WAV to ASF as easily. -
Well, it all worked except the audio file didn't really do anything; Tegrity just put that file there for fun.
Anyways, I've found that I can use AVS Video converter to amplify the file. Since I'm using the freeware version, I think I'm going to end up with a watermark on my video unfortunately...
I might try to use mplayer to convert to an easier format to deal with and try that if the watermark is too obnoxious.
EDIT: Well AVS doesn't seem to be able to output files as ASF files...
EDIT2: I forgot to mention that now the ASF file is both audio and video, before I was only dealing with audio and AVS will not work with audio only ASF -
Yeah, it sure is
Well, I spent some time in the mplayer IRC and they helped me out quite a bit. Unfortunately, mplayer ASF files will not play in Windows Media Player, but they told me that ASF is really close to WMV.
I ended up using AVS, even though the watermark IS obnoxious, and saving as a WMV. At that point, I just changed the extension to ASF, and it seems to work for me.
I have some noise in the video, but it is louder now, so that's good enough for tonight.
ASF problem playing audio
By Neomorpheus in forum Software PlayingReplies: 2Last Post: 14th May 2011, 02:56 -
converting asf file audio sync issues
By andy99 in forum Video ConversionReplies: 4Last Post: 21st Jan 2011, 03:09 -
By andy99 in forum AudioReplies: 4Last Post: 20th Jan 2011, 19:41 -
asf to vc-1
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 16th Dec 2009, 14:27 -
vc-1 to asf
By sampalmer21 in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 19:47
