  1. Using Firefox.
    Removing the Flash plug-in is not an option since I frequent YouTube.
    The only way I know of how to block the Flash ads is installing a plug-in that requires JavaScript. But with JavaScript enabled, the JavaScript ads would kick in instead.
    Is there a way I can get Flash to be enabled only in YouTube and disabled for all else? Or something similar to that.
  2. I use an old version of Internet Junkbuster that I modified. When I hold down the left control key the filtering is bypassed. I block all SWF by default. If I want to see a Flash video I just hold down the control key and refresh.
  3. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Flashblock
    Blocks all flash and replaces it with a little "f" symbol. If you want to view that particular flash just click the little "f"
    Donadagohvi (Cherokee for "Until we meet again")
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    NoScript also blocks Flash, as I recall. You can have it block everything, so to speak, and then just whitelist YouTube.
