Does anyone know the technical specifications for the bandwidth on component video (per each wire) for the standard HD resolutions and frame rates?
I need to know this because
1) if I build an active balun, I need to know the minimum bandwidth requirements of the op amps. and
2) this is how the transformers for baluns are rated.
I am an electrical engineer, so I know what I am asking, I just may not have asked it well. Google searching just has not been able to produce a good answer for me.
In round numbers for studio measurement. Consumer products would be less.
ITU-Rec 601 480i/576i Y Channel 13.5 Ms/s, 6.75 MHz Nyquist for D/A.
Analog component can go out to >9MHz to 15MHz from some cameras (e.g. HD studio camera feeding analog 480i).
480p/576p Y Channel ~ 12-30 MHz+
720p Y Channel ~ 30 MHz+
1080i Y Channel ~ 30 MHz+, Pb Pr ~ 15 MHz
1080p Y Channel ~ 60 MHz+, Pb Pr ~ 30 MHz
480p RGB ~ 12-30 MHz+ per component
1080p RGB ~ 60 MHz+ per component
Op Amps should exceed anticipated signal bandwidth. Tek scopes and probes are flat to 1 GHz.
See this Tektronix App Note.
"High Definition Analog Component Measurement"
http://www.tek.com/Measurement/App_Notes/25_16653/eng/25W_16653_0.pdfRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Very Interesting. Thank your for the link to the Tek Document.
If I have a chance to put some devices on the tek computerized scope at my office, I'll post frequency domain plots.
SR-W7U Component output
By Cingular in forum Capturing and VCRReplies: 1Last Post: 19th Jun 2011, 15:14 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46 -
Is there a drop-dead date for high def output over component cables?
By yoda313 in forum Capturing and VCRReplies: 12Last Post: 26th Jun 2009, 23:42 -
sony hdr sr12 output to klv32s200a via component
By tomhanks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Dec 2008, 17:01 -
ATI X1900 GT Component Output
By DVDDave in forum ComputerReplies: 2Last Post: 13th Feb 2008, 16:41
