Hi,
newbie to all this.. I just brought myself a HG10, rather happy with it, but it records in MTS.
After upgrading my PC, now I can finally do something with these files, at this stage just burning onto a DVD.
Anyway, I've just reinstall Real Alternative 1.84 & ffdshow_beta5_rev2033_20080705_clsid
but when I play the MTS files, I get a screen within a screen, its just like a zoom.
This box stays there permanently and its rather annoying... this only appears when I play mts files and if I use the same player for other type files, everything is normal. ie. this zoom box is gone.
Any idea on whats wrong and how do i get ride of it?
Can anyone tell me what other s/w i should install for working with MTS files? like codecs, tools, etc..
Thanks in advance,
Jason.
	Not sure about your 'screen within a screen' problem, but you can do a all forum search for ' MTS ' and ' AVCHD ' and find out quite a bit about your format and how to work with it. This one from Soopafresh is fairly recent: https://forum.videohelp.com/topic346331.html?highlight=mts
 And welcome to our forums.
	Hi redwudz,
 thanks for the thread.. will have a read.
 btw.. my screen within a screen is now fixed... I uninstalled all the codec, etc.. so now only using haali, ffdshow & RealALT 1.84.
 The only prob now seems to be some buffering type issue, where playing the VDO, the video starts to stuttler, freeze, etc..
 any suggestions?
 I've already set ffdshow to deinterlacing.
 thx.
  Why Is Playing Back .mts Files From A Camcorder On HDTV Better Than A PC?By JohnnyGalaga in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2011, 15:00
  What Media player is best playing MTS. video filesBy marionr26 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 33Last Post: 14th Aug 2010, 19:30
  Dirty Harry series ripping & playing problemBy adamf154 in forum Blu-ray RippingReplies: 5Last Post: 24th Jul 2010, 16:18
  Problems playing MTS/Avchd fileBy statang in forum Software PlayingReplies: 7Last Post: 29th Jul 2009, 04:13
  Do QuickTime Alternative & RealAlternative work well together w/browserBy usually_quiet in forum ComputerReplies: 2Last Post: 16th Jun 2007, 11:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
