I was going my make a .mkv from a VC-1 video track and an AC3 audio track using mkvmerge.exe of MKVtoolnix, but it won't accept VC-1 video. Are there any other good software for doing this that accepts VC-1?
BTW, I also have an EAC3 (higher definition) version of the audio track, but is that even supported by PCs?
Results 1 to 23 of 23
It should be possible to make an MKV container with VC-1 video as MKV supports just about anything for audio and video. I don't create MKV files so I have no suggestions, but perhaps another free tool will do the job.
I think by EAC3 you mean what is usually called DD+. There are various filters around that can play these on PCs, but I think all of the filters cost money and at this time what they actually do is either convert the audio to a slightly lower quality format or just play the AC3 core inside the DD+ file. -
If you are using the GUI, you have to set the program paths on the 1st tabOriginally Posted by mkvbob
Alright, I've set the paths.
First I load the two eac3/vc1 source files and switch to mkvmerge tab where I then load the vc1 source file as input, enter an output name and click "add to batch listing" (just to test it without adding sound). I go to the batch tab and run it, but it just gives me an error log that says "Error: No input files were given. No output will be created."
Could someone please help me with this or link me to a tutorial or something? -
You can download a tutorial here
http://briefcase.yahoo.com/bc/yraen@sbcglobal.net/lst?.dir=/Eac3to+and+More+GUI&.order...ase.yahoo.com/
if you have more questions you can find the proper threads here (note the GUI doesn't support all the features as the command line, and hasn't been updated in awhile):
EAC3TO GUI thread
http://forum.doom9.org/showthread.php?t=135095
EAC3TO thread
http://forum.doom9.org/showthread.php?t=125966 -
alright i'm assuming you ripped this off of a hddvd. you should have two evob files or they could be called feature 1 and 2. open eac3to gui where it says source file load the first evob or feature file then under that there is a joining click browse and load the second evob or feature.now under destination erase the evob extension and put mkv like feature1joined.mkv.next click on the conversion options 2 check demux first video track and check strip vc-1 pulldown then click convert when it's done you should have your joined file and the audio will be demuxed seperately so when you browse to the folder you should have your video and 2 or3 audio tracks. now you should be able to play the video if you can't play the video then it will not convert. if it plays it will convert. now load it into xvid4psp there is a tutorial for this. as for the audio you have to convert it to ac3 for it to work. once the video is done load the video and audio file in mkvmerge and mux them together. if you were trying to demux with tsmuxergui it will not work. i have done it many times this way and it does work.
It doesn't recognize the vc1 file when set to 'all media files,' but when I set it to 'all files' instead and open my vc1 it returns an error saying 'FFmpegSource: Video track is unseekable.' Same thing happens if I try to open the source .TS stream. I can play the .TS with VLC though and the HD video on it is perfectly viewable.
I've done that some months ago, and just for learning purposes,
but I do not recall all the "gory" details of the method.
IIRC,
I used the DirectShow filter vc1esparser.dll plus Gabest's MatroskaMuxer
for putting an elementary VC-1 stream into an MKV file.
You'll need to know how to use GraphEdit, n.b. Anyway, I presume that
the latest version of Haali's MKV Muxer should be able to deal with a VC-1 .TS file.
HTH. -
mkvbob wrote:
Apparently something on your PC has been screwed.Haali will just stand at 0.0% for hours with no progress being made
if I feed it the .TS and start muxing.
A general registry cleaning might fix that issue.
Difficult method:where can I get the vc1esparser.dll?
goto M$'s web site, find and download a certain SDK,
uncompress it with UniExtract, copy the damn dll, delete the
documentation files that you will not want to use.
Easy method:
https://forum.videohelp.com/topic349078.html#1898810
Good luck!
Ok, so I've got the .dll, but how exactly do I open the vc1? Do I need to put the .dll somewhere or do i have to load it with graphedit somehow? (As I said, I'm a newbie with graphedit and I can't find any tutorials for the damn thing, so please help me.)
When I run the regsvr32 I get an error message saying:
"The module 'vc1esparser.dll' may not be compatible with the version of Windows that you're running. Check if the module is compatible with an x86 or x64 version of regsvr32.exe"
I'm using Vista 64, so should I put the .dll somewhere else like SysWOW64 or maybe use another command? -
Vista 64, huh? That would explain a lot of things.
In this case, you'd better give a try to Inspector.Gadget's suggestion. -
Hmm, this is wierd, when I use VLC media player to view the 2gb large output .avi they are like really jerky in their playback, as if the picture was shaking back and forth or something (can upload a sample if you need one), but when I then use WMP 11 instead, they are perfectly fine. I'll use them with mkvmerge and see what the final .mkv will be like.Originally Posted by Inspector.Gadget
btw, is there any way to make vc12avi just give me one big 15.6gb .avi instead of 2gb segments? -
@mkvbob - You might ask Crypto over at Doom9 (he's the guy behind DVBPortal and all its software projects). I've only used VC12AVI once and wasn't aware of the splitting behavior. Might it be encountering discontinuities in the stream? In any case, if the stream is OK and the final AVI is just split correctly, you should be able to append either the AVIs or MKV segments with MKVMerge. Crypto would know better; here is the discussion thread for the tool: http://forum.doom9.org/showthread.php?t=128943.
Edit: Apparently the tool splits files into 2GB pieces, but I think you can append these using MKVMergeGUI before muxing. I don't have a convenient >2GB VC-1 file with which to test.
Tools for editing MKV file.
By wisitch in forum EditingReplies: 2Last Post: 9th Oct 2010, 01:31 -
DVD to MKV Help me choose best tools and settings
By alc112 in forum Video ConversionReplies: 2Last Post: 14th May 2010, 23:32 -
My MKV file already has AAC audio so the conversion tools arent working
By animlchin in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 18:58 -
tools needed to make a streaming website
By mr-scarface in forum Video Streaming DownloadingReplies: 5Last Post: 29th May 2009, 19:49 -
any good tools MKV -> AVI with multi-track audio support?
By helloguys in forum Video ConversionReplies: 1Last Post: 18th Nov 2007, 12:41
