I'm having problems with Sony Vegas 8. Everytime I try and render, it crashes out after 50-80%. My first thought was corrupt files, but upon removing the suspect clips, it began crashing at various other points in the render process. It started with WMV, but now it appears to be happening with every codec. I'm using Win XP on a single core Xeon 2.8ghz(2x) machine. The files are from a Sony Ex1 so they're .MXF format. I have tried rendering suspect files to other format like AVI and replacing them in my original troublesome timeline, but also no change. Tried rendering without audio, no change. I'm mainly rendering in 720p but 1080p is failing also. Help me please.
You might be running out of RAM. Try rendering a shorter segment.
Are you getting an error message? What kind of crash? BSOD or something else?
Check your temps with coretemp. If they are high, clean out the dust in your HSF, ensure good airflow etc...
Might be a good idea to check your ram integrity as well with memtest64+ -
I've never seen this with Vegas but in older days I experienced this when tmp files filled the hard disk.
http://www.kiva.org/about -
Thanks for your replies.Here is the error I get, and variations of it:
"Sony Vegas Pro has encountered a problem and needs to close. We are sorry for the inconvenience."Code:Error Signature:AppName: vegas80.exe AppVer: 8.0.0.260 AppStamp:48c7daa4 ModName: vegas80k.dll ModVer: 8.0.0.260 ModStamp:48c7d963 fDebug: 0 Offset: 00047d3f
Best call Sony Creative Software tech support in Madison. They are usually helpful.Originally Posted by dfgh11Recommends: Kiva.org - Loans that change lives.
Need help - rendering in Vegas
By Rairun in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2011, 19:51 -
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Rendering with Vegas 8
By seven1970 in forum EditingReplies: 27Last Post: 23rd Feb 2009, 12:44 -
Sony Vegas 8.0c (build 260) crashing while rendering, using Magic Bullet
By tranzadikt in forum EditingReplies: 0Last Post: 6th Dec 2008, 14:05 -
Rendering to Flash from Vegas?
By grendizer in forum EditingReplies: 7Last Post: 11th May 2008, 16:13
