my brother just bought a pawn shop (no manual)dv camcorder (jvc gr-dvm70), we want to capture from the cam but it only came w/a firewire output cable(doh! again)
So I guess I'm gonna need some sorta firewire capture card.
I have a radeon vivo (composite)![]()
I guess I'm asking for buying advice since im a total n00b at dv capture and have only composite video input.
Would an ATI DV~WONDER do what i need? or should I shoot for a higher end card (I have no idea what makes one different from the other) ?
Or is there an AGP video card w/firewire inputs? (under $200)
any advice?
you should be able to get a firewire card that fits in your computers pci slot "not agp" for less than $100.00, some even come bundled with video editing software. your favorite computer store can help you out.
Go to www.pricewatch.com and you should find some for a pretty low price. Around 40-60 dollars. Have fun with the DV capture. I hear it's one of the BEST ways to capture.
Yep you need a firewire card. If your looking for suggestions......I like Pinnicle. They make pretty good stuff at a decent price.
The key thing on any Firewire card is that it is OHCI compatible. I bought the generic store brand from CompUSA for $50 and it works perfectly. Your operating system should already have a driver, so you just install and go.
Note, that you cannot "capture" unless the DV camcorder has analog input. I'm not familiar with the GVC so I would check out their website. -
i bought a COMPUSA brand Firewire card. it comes with cabel and basic visualstudio software. i bought it for 29.99 about two months ago. you just need a free PCI slot in your computer.
________________________
Baskaran Swamiappan
baskarans@yahoo.com 8)
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 09:55 -
Is a HDMI capture card or firewire better for transferring dvr recordings?
By yoda313 in forum Capturing and VCRReplies: 0Last Post: 9th Dec 2007, 14:42 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
