Hi Guys
New to the site so Hey! to everybody. I hope I'm in the right section for my problem.
The problem I'm having is recently the DVD's I burn ( Using WinAVI ) seem to have about a 30 to 35% chance that they'll play properly, by that I mean they will start off playing OK then they start to kind of skip and or slow down and eventually will freeze. As I said I use WinAVI which I find is great and I use DVD +R disc's and haven't any problems at all up until recently. I'm hoping somebody may be able to help me out with this, any help would be greatly appreciated. Thanx guy's.
	Besides using reliable media, try burning with Imgburn ....
 Sorry but I don't see too many users of WinAvi, claiming it works "great"
 I'd try FAVC ,DVDFlick or ConvertxtoDVD, if you're converting avi to DVD..." Who needs Google, my wife knows everything"
	By "reliable" they mean use better quality DVD+Rs. Since you didn't give the brand we can't know if that's really the problem, but poor quality discs can certainly create those symptoms. And, as mentioned, ImgBurn is the burning app of choice these days.
 And although WinAVI is crap, I don't think by itself it's responsible for the problems with the skipping and freezing. Nor was t0nee1 suggesting it was responsible. He was suggesting that in the future you use a better conversion program.
	Oh OK I see what they meant. As far as disks I use the Sony DVD+ R. I just checked out ImgBurn and it seemed to work well but I haven't had a chance to see if the problem was solved by using it. I'll post back once I've checked. Thanks allot Manono and everybody else that responded.
  No sound when playing playing burned DVD on stand alone playerBy ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11
  LG LHB953 not playing burned copies of my DVD'sBy SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43
  DVDs not playing properlyBy peter31 in forum Newbie / General discussionsReplies: 4Last Post: 27th Oct 2009, 09:24
  Videos not playing properly - Codec Problem - HELP PLEASEBy Man-bear-pig in forum Software PlayingReplies: 1Last Post: 10th Feb 2008, 00:59
  Problem Playing DVD I burnedBy hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 08:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
