A local pro just told me to use a gel to make sure veins don't show up on video shot with normal compact flourescent lighting. Not sure if I need to spend the extra $20 to pick up some gels (ie. cellpophane type material) to place over the flourescent lights.
Apparently, lower cost flourescnet lights can show veins? Anyone have issues with this?
	Isn't that why orange studio makeup is used?
 I never heard of veins popping but without makeup pale complexions turn ghostly.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I was wondering about the same thing but apparently, as per the pro, lower cost floruescent bulbs tend to do this. Maybe it's the lower temperature (3K range instead of the 5K range)? Not too sure so thought to check here first. I am leaning towards trying them out first and only buying the gel if results aren't good. Any thoughts?
	You could always call a TV lighting vendor.
 http://www.google.com/search?hl=en&q=Fluorescent+TV+Lighting
 http://www.creativehat.com/Filmmaking/a040601a.htmRecommends: Kiva.org - Loans that change lives.
	I've been in the production field since the late '70s, and I've never experienced anything like that. Frankly, I'm convinced it's a myth. If someone has evidence to prove otherwise, please post some screenshots.
	After all the great feedback, I think I am going to hold off on teh gels until I see the final results. Thanks all!
  Lighting problemBy samoyed in forum Newbie / General discussionsReplies: 5Last Post: 11th Mar 2009, 18:56
  LightingBy ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Feb 2009, 21:54
  LightingBy kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2009, 20:17
  Home LightingBy assman24 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 13:47
  Which Lighting is Better?By wan2no in forum Newbie / General discussionsReplies: 9Last Post: 13th Sep 2007, 23:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
