I create slideshows using Proshowgold and then I want to publish them as flash in my blogs. Proshow produces 3 files namely a flash object, a flv file and an html fle. Google blogs do not accept flash files. It is possible to upload the flash file to googlepages and put the html in the blog. In this way I managed to publish 2 videos created using Wax and Wink. Now I try to publish the slide show flash file, the clip appears but does not play. In one case I also uploaded the accompanying flv file and the flash file played. But this is not a valid solution because the flv file is generally larger than 10 MB and is not accepted. I thought of making the flv smaller using Riva encoder. But here sometimes it works and sometimes doesn't. First question: should the flash and flv files always be kept together for the flash file to play? Secondly, are there certain rules to be respected when decreasing the size of the flv file. Thanks for helping.
Yep, you must upload both the flv and flash.
If you want smaller file size use lower video bitrate. Check if you can set the video bitrate or any quality settings in Proshow and lower it. You can also reconvert FLV using SUPER. Or convert to mp4(with h264 and aac) using xvid4psp or avidemux, it is supported by flash.
How to capture/record streaming Google, youtube,Flash, ASF,WMV,RM,Quicktime
By Baldrick in forum Newbie / General discussionsReplies: 219Last Post: 21st Feb 2012, 23:41 -
Posting video in blogs
By SearchQuality in forum Video Streaming DownloadingReplies: 5Last Post: 5th May 2009, 15:15 -
Convert youtube, Google flash video to DVD
By Baldrick in forum User guidesReplies: 69Last Post: 30th Jan 2009, 08:11 -
How to Publish Flash Videos in Your Personal Home Page?
By Nitemare in forum Video ConversionReplies: 1Last Post: 7th Nov 2008, 02:37 -
Google Is putting out it's own web browser. Google Chrome
By freebird73717 in forum ComputerReplies: 35Last Post: 24th Sep 2008, 01:38
