    Apr 2003
    Hey Guys!
    I have an AVI file that when played on any media player (Divx Player, WMP etc) I cannot seem to hear the audio, I tried using GSpot to analyze the file to see if I had the correct Codec installed and the result was that I do have the Codecs installed.
    Any ideas?!
    What is the audio codec?
    Try also play with vlc media player(it has builtin codecs).
    Apr 2003
    GSpot tells me the codec is: 0x2000 (Dolby AC3) AC3
  4. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    Install ac3 filter and try again.
    Apr 2003
    Thats done the trick sanderman! Thanks!
