I need to use the Xvid codec, mux in AC3 audio, and put it into an MP4 container to allow for chaptering.
I'd love to use VirtualDub MOD, but it doesn't output to MP4. What can I do?
(Please no arguments about how one container is better than another, or one codec is better, this is what I need to accomplish.)
guns1inger is quite correct - the MP4 container does not support AC3 audio. You have to use AAC, Apple Lossless, MPEG audio (including MP3 and MP2) or some weird, little used formats that I don't remember. DTS and AC3 are not supported. What this means in practical terms is that you may not be able to find anything that can put AC3 audio in the container or if you do somehow create it, it may not play back correctly. His suggestion to try Xvid4PSP is probably your best chance to do this, if it even can be done.
AC3 in mp4 was added to the mp4 spec last month:
http://forum.doom9.org/showthread.php?p=1173576#post1173576
I don't know if Xvid4PSP's been updated to support it yet or not, but a test version 0.9.3 of MP4Muxer with ac3 support is available but not yet released. You may be able to get it by PMing Crypto:
http://forum.doom9.org/showthread.php?p=1187836#post1187836 -
The latest Xvid4PSP (installed today) doesn't support encoding to AC3 when using mp4 as an output container. I don't know if it will mux AC3 using copy mode if your source already has AC3 audio. I suspect that it probably won't, and that the underlying applications used by Xvid2PSP don't support it yet either.
Read my blog here.
MP4/AAC -> XVid/AC3 6ch
By brugi in forum Newbie / General discussionsReplies: 16Last Post: 20th Aug 2014, 21:43 -
M4V to MP4 Container help
By Cornholio77 in forum Video ConversionReplies: 5Last Post: 1st Jan 2012, 03:28 -
Help! - How to put xvid into an mp4 container.
By jamsponge in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 10:54 -
h.264 in mp4 container?
By savvyguy in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 11:25 -
Have you ever seen an .mp4-container TV channel???
By georgekellerman in forum DVB / IPTVReplies: 2Last Post: 10th Aug 2007, 11:45
