Hi,
I try to burn a backup (original is a dvd-5) with ImgBurn but I receive the "Potential 'WaitImmediateIO' Deferred Error" message when trying to finalize the disc.
I got this message on this movie. I burn two other disk and it was successful. I use the same disc for all the burns.
1. I try with dvd decrypter in "Iso read" and write with ImgBurn.
2. I rip with decrypter and then burn the folder with Img Burn.
Same error.
Is it possible this error is caused by the warning "Possible structure protection found. Dummy sectors will be inserted when needed" in dvd decrypter ?? During the rip, dvd decrypter doesn't mention it wrote dummy sectors.
Do I need to use FixVTS or this dvd ???
here is the burning og from imgburn:
The burned disc is perfectly playable on my computer but my standalone dvd player doesn't recognize it => "unreadable disc".Code:I 23:30:22 ImgBurn Version 2.4.2.0 started! I 23:30:22 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3) I 23:30:22 Total Physical Memory: 1.048.048 KB - Available: 617.588 KB I 23:30:22 Initialising SPTI... I 23:30:22 Searching for SCSI / ATAPI devices... I 23:30:22 Found 1 DVD-ROM and 1 DVD±RW/RAM! I 23:30:44 Operation Started! I 23:30:44 Building Image Tree... I 23:30:44 Checking Directory Depth... I 23:30:44 Calculating Totals... I 23:30:44 Preparing Image... I 23:30:44 Checking Path Length... I 23:30:44 Contents: 44 Files, 2 Folders I 23:30:44 Size: 3.932.960.768 bytes I 23:30:44 Sectors: 1.920.391 I 23:30:44 Image Size: 3.933.634.560 bytes I 23:30:44 Image Sectors: 1.920.720 I 23:30:44 Operation Successfully Completed! - Duration: 00:00:00 I 23:31:10 Operation Started! I 23:31:10 Building Image Tree... I 23:31:10 Checking Directory Depth... I 23:31:10 Calculating Totals... I 23:31:10 Preparing Image... I 23:31:10 Checking Path Length... I 23:31:10 Contents: 44 Files, 2 Folders I 23:31:10 Size: 3.932.960.768 bytes I 23:31:10 Sectors: 1.920.391 I 23:31:10 Image Size: 3.933.634.560 bytes I 23:31:10 Image Sectors: 1.920.720 I 23:31:15 Operation Successfully Completed! - Duration: 00:00:05 I 23:31:16 Operation Started! I 23:31:16 Source File: -==/\/[BUILD IMAGE]\/\==- I 23:31:16 Source File Sectors: 1.920.720 (MODE1/2048) I 23:31:16 Source File Size: 3.933.634.560 bytes I 23:31:16 Source File Volume Identifier: BONUS_OBISPO I 23:31:16 Source File Application Identifier: IMGBURN V2.4.2.0 - THE ULTIMATE IMAGE BURNER! I 23:31:16 Source File Implementation Identifier: ImgBurn I 23:31:16 Source File File System(s): ISO9660; UDF (1.02) I 23:31:16 Destination Device: [4:0:0] TSSTcorp CDDVDW SH-S203B SB03 (F:) (ATA) I 23:31:16 Destination Media Type: DVD+R (Disc ID: MCC-004-00) (Speeds: 4x; 6x; 8x; 12x; 16x; 18x; 20x) I 23:31:16 Destination Media Sectors: 2.295.104 I 23:31:16 Write Mode: DVD I 23:31:16 Write Type: DAO I 23:31:16 Write Speed: 4x I 23:31:16 DVD+R Reserve Track: No I 23:31:16 Link Size: Auto I 23:31:16 Test Mode: No I 23:31:16 OPC: Yes I 23:31:16 BURN-Proof: Enabled I 23:31:16 Book Type Setting: DVD-ROM I 23:31:36 Filling Buffer... (40 MB) I 23:31:37 Writing LeadIn... I 23:31:38 Writing Session 1 of 1... (1 Track, LBA: 0 - 1920719) I 23:31:38 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 1920719) I 23:43:34 Synchronising Cache... I 23:43:38 Closing Track... I 23:43:41 Finalising Disc... W 23:43:55 Potential 'WaitImmediateIO' Deferred Error - (99%, 0/3) - Program Memory Area Update Failure W 23:43:55 Finalise Disc Failed! - Reason: Program Memory Area Update Failure W 23:43:55 Retrying (1 of 3)... I 23:44:09 Image MD5: be2185773993a8c115ab12ba5b19fe93 I 23:44:09 Operation Successfully Completed! - Duration: 00:12:53 I 23:44:09 Average Write Rate: 5.380 KB/s (3.9x) - Maximum Write Rate: 5.566 KB/s (4.0x) I 23:44:12 Operation Started! I 23:44:12 Source Device: [4:0:0] TSSTcorp CDDVDW SH-S203B SB03 (F:) (ATA) I 23:44:12 Source Media Type: DVD+R (Book Type: DVD+R) (Disc ID: MCC-004-00) (Speeds: 4x; 6x; 8x; 12x; 16x; 18x; 20x) I 23:44:12 Image File: -==/\/[BUILD IMAGE]\/\==- I 23:44:12 Image File Sectors: 1.920.720 (MODE1/2048) I 23:44:12 Image File Size: 3.933.634.560 bytes I 23:44:12 Image File Volume Identifier: BONUS_OBISPO I 23:44:12 Image File Application Identifier: IMGBURN V2.4.2.0 - THE ULTIMATE IMAGE BURNER! I 23:44:12 Image File Implementation Identifier: ImgBurn I 23:44:12 Image File File System(s): ISO9660; UDF (1.02) I 23:44:12 Read Speed (Data/Audio): MAX / MAX I 23:44:12 Verifying Session 1 of 1... (1 Track, LBA: 0 - 1920719) I 23:44:12 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 1920719) I 23:48:35 Device MD5: be2185773993a8c115ab12ba5b19fe93 I 23:48:35 Image MD5: be2185773993a8c115ab12ba5b19fe93 I 23:48:35 Operation Successfully Completed! - Duration: 00:04:22 I 23:48:35 Average Verify Rate: 14.661 KB/s (10.6x) - Maximum Verify Rate: 20.952 KB/s (15.1x) I 23:48:37 Close Request Acknowledged I 23:48:37 Closing Down... I 23:48:37 Shutting down SPTI... I 23:48:37 ImgBurn closed!
Is there a problem with the source files ??????
dvd decrypter is old and out of date, and isn't updated anymore. it can't handle newer protection on dvds. you will need to rip using anydvd or dvdfabdecrypter.
Similar problem noted at the ImgBurn forums, with the same drive. See the first paragraph in mmalves' reply here:
http://forum.imgburn.com/index.php?s=&showtopic=7776&view=findpost&p=76949
HTH,
Jim
[ASK] Error Burn BD with Imgburn
By m1x in forum Blu-ray RippingReplies: 5Last Post: 30th Jun 2010, 11:25 -
ImgBurn error
By tim_ver in forum Authoring (DVD)Replies: 10Last Post: 27th Dec 2007, 17:09 -
ImgBurn I/O Error
By trunkims in forum Authoring (DVD)Replies: 12Last Post: 12th Sep 2007, 17:43 -
Imgburn Error HELP
By jessandjeff123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Jun 2007, 13:42 -
ImgBurn Error?? I keep getting this...
By sandman423 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2007, 00:08
