I am currently trying ffmpegX out by converting a DVD to an Xvid .avi file. The DVD source is PAL, 25fps, non-anamorphic with an aspect ratio of around 1.59:1 (at least according to reviews). Now what do I set the Autosize function to? It seems limited to only a few of aspect ratios used in movies: 2.35:1, 1.85:1, and then there are the "video aspect ratios" of 16:9 or 4:3.
The documentation on the website does not really say much, only that you need to choose the aspect ratio of the film. But what if you have a film with with an unknown or lesser known aspect ratio (there are for example literally thousands of films filmed in 1.66:1)?
Also what does the "(keep height)" refer to among the options in Autosize?
Jens
DVD only supports two aspect ratios: 16:9 and 4:3. Any video that is not one of those aspect ratios is padded with black borders to fill out the frame to make it one of those aspect ratios. If you are not cutting off the black borders you don't need to worry about the AR of the original film.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 02:53 -
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 19:44 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 11:25 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 17:40
