Neuron2/Don Graft has a new product which can speed up the transcoding of AVCHD and other h264 streams. It uses the new CUDA enabled drivers which work on the Nvidia 8xxx series or higher video cards.
The decoder is similar in usage to his DGavcdec package. A few features:
1) No longer Libavcodec based, so many more types of AVCHD camera files will convert without artifacts.
2) Can use the built-in Nvidia deinterlacer, which is fast and the quality is excellent.
3) I've tested some conversions using my old Nvidia 8500GT card and v177.92 of the drivers. In some cases, performance was 3x faster than the standard DGavcdec version.
Not free ($15), but worth the money if you're converting a lot of files or are pressed for time. Although I haven't tried it, I suspect scrubbing in Premiere would be accelerated (if used along with the Avisynth for Premiere plugin)
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
Of course, you need to have an Nvidia video card installed. And certain older 8000 series cards won't work. Your card must have VP2 capability. See this table to determine if your card is compatible:
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_Graphics_Processing_Units#Features_3
Example:
Here's a file which is problematic with the libavcodec based DGavcdec
p00005.mts
Notice the artifacts when it is transcoded with the libavcodec based DGavcdec
dgavcdec_p00005.mp4
And the absence of artifacts when transcoded with the Nvidia version of DGavdecNV
nvidia_p00005.mp4
				Results 1 to 1 of 1
  Playing AVCHD on Nvidia 8600 without stutterBy P.J in forum Software PlayingReplies: 3Last Post: 5th Jun 2011, 11:51
  ATI or NVIDIA capture card for VHS?By Smile_M in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 07:43
  Can Nvidia Tuner box be modded to work w/o card?By perceptionist in forum ComputerReplies: 1Last Post: 6th Nov 2009, 01:48
  PCLinuxOS 2007: Problems with my Nvidia graphics cardBy FulciLives in forum LinuxReplies: 24Last Post: 1st Aug 2007, 17:37
  Nvidia 6800 GT Video Card ProblemsBy theyuw in forum ComputerReplies: 12Last Post: 2nd Jul 2007, 19:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
