Hi,
I tried buring DVD (contents of Video_TS folder) on to a dual layer disc using nero 7.10 but it failed at finalizing Disc. The disc is playable until it needs to go to second layer.
My original is now so messed up it can't be read otherwise I would of tried to create iso image and burn that. So How can I successfully burn the DVD to Dual Layer disc?
Use ImgBurn. Nero is notorious for NOT burning DL discs correctly. If your DL disc is DVD-R DL instead of DVD+R DL, you should know that these are much trickier to burn, even with ImgBurn. ImgBurn has some Jump Layer option that I believe you will specifically have to set for DVD-R DL burning to work. Do NOT use that option on DVD+R DL media! Finally, note too that burning any brand other than Verbatim is not advised and those who burn other brands of DL media post here all the time asking why their burns don't work.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Burning AVCHD File To Dual Layer DVD
By Falco21 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Mar 2011, 11:16 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 21:08 -
Dual Layer Burning Using Nero 6
By EddieK in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2007, 06:58
