I'm wanting to buy this adapter to get a Video signal from my laptop to a LCD HDTV via an upscaling converter. Iam puzzled by the audio outlets. I understand that the VGA is only a video signal, why put audio outlets?
Can anyone enlighten me?
				Results 1 to 17 of 17
	"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	That's probably component video, not composite video and audioL/R. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	That adaptor is for a specific device that includes audio and composite/svideo on a D15 port. It will not work with "normal" VGA ports at all.
	Thanks Guys, I'll buy it anyway as I'm sure the video outlet will work and it"s only $4. "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	Why are you sure the video will work? Composite/s-video is not standard on VGA ports (although some graphics cards and laptops have it on some of the otherwise unused pins). A simple cable can't convert VGA to composite/s-video.Originally Posted by tweedledee
	The titling makes it look like it will work, but the price guarantees it won't. There would have to be some special electronics to make it even possible, but there's no way it could have that and sell for $4. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	You will may need a VGA to s-video scan converter:
 http://www.cablestogo.com/product.asp?cat_id=3103&sku=27389
 Note that s-video picture quality is far lower than VGA, even with the best scan converter. At best, the luma resolution will be about 640x480, the chroma resolution about 320x480.
	I'm not trying to convert anything with this. I am sure I can get a video signal which I can convert this upscaling converter. I'm not going to slash my wrists over a few bucks, so if it doesn't work then too bad.
 At my age my eyes are not that brilliant and the whole exercise is just something to keep me busy. I'll let you know how it transpires.
  "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	Won't work 99.98%. I'm tired of explaining the 0.02 % times it may work.Originally Posted by tweedledeeRecommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	If it works let us know. If it doesn't put some screws in that knife door.Originally Posted by tweedledee
 All that does is poorly display SD composite at best.Recommends: Kiva.org - Loans that change lives.
	That doesn't make any sense. You want to take composite or s-video from you laptop's VGA port (if it even has it) and the convert to VGA to feed a monitor? Why don't you just get a VGA cable and feed monitor directly? The picture quality will be far better.Originally Posted by tweedledee
 And you still haven't said why you're so sure you can get s-video or composite video from the laptop's VGA port. Does the manual say your laptop has that ability? Does that cable manufacturer say it's for your model laptop? VGA and TV video are two completely different, incompatible systems.
	That's what I'm doing now. I am hoping I can get a better picture by placing this converter between them. Here is what they say it does.Why don't you just get a VGA cable and feed monitor directly? The picture quality will be far better
	You will get a much worse picture, not a better picture.Originally Posted by tweedledee
	I bet you a couple of beers that I won'tOriginally Posted by jagabo
 I should be able to tell you in about 10 days, at that stage I'll be either gloating over my win, or humbly
 apologizing. Don't worry mate, the sun will still come up, even if it's a dismal failure. "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	Lock up those knives. Recommends: Kiva.org - Loans that change lives.
	"Oh Ye of little faith" Just wait till next week. In the meantime the Knife drawer stays OPEN.Originally Posted by edDV
 Haven't you Guys realized that eBay doesn't sell crap?????? "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	It's not a matter of faith. It's an understanding of how TV and computer video works.
  Laptop VGA-out to old (not-HDTV) TV S-video inBy ahwitz in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2010, 11:23
  vga to hdtv produces linesBy sitlet in forum ComputerReplies: 4Last Post: 14th Jun 2009, 20:42
  laptop with only VGA to VGA-less HDTVBy liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16
  HD to HDTV from laptop with VGA/S-Video....By snadge in forum Newbie / General discussionsReplies: 10Last Post: 14th Jan 2008, 07:44
  Should I use Component or VGA for HDTV?By jdmbo1 in forum Media Center PC / MediaCentersReplies: 16Last Post: 22nd Sep 2007, 22:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
