Hello, I want to compile short clips from DVD's I own. To encode them so that I can play them on my Zen. I am new to video editing and need a good beginner's program.
Thanks for any and all help!
Mark
Commercial DVDS? Then would I use dvd shrink in the reauthoring mode to cut out the clips you want(you might need to use dvdfab decrypter for newer dvds). You will get one vob for each cut. You can then convert the vobs to avi xvid mp3 using WinFF.
Thanks baldrick, I've downloaded these and will try and figure them out as soon as I can find the time. I'll post on how it turns out. Freeware, that's great!
Mark
Can I do a simple fade in/out on clips pulled from BD without re-encoding?
By Dan Miller in forum EditingReplies: 4Last Post: 7th Jun 2010, 01:31 -
Vista compatible mp3 editor which will save clips at 48kbps
By wetcamelfood in forum AudioReplies: 10Last Post: 17th Jun 2009, 17:39 -
Joining 2 different video clips without re-encoding one of them?
By Og in forum EditingReplies: 2Last Post: 7th Jan 2009, 02:54 -
DVD playback has blank/dark clips
By NewbieWithAMovie in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2008, 23:26 -
Which Multimedia Framework or Playback Engine should I use?
By csh in forum ProgrammingReplies: 2Last Post: 31st Dec 2007, 05:45
