Greetings,
I have been doing some conversions from AVI to M2V using TMPGEnc Xpress 4.0, which now has a bitrate calculator. I used to use the online Bitrate Calculator, but I guessed the one provided with TMPGEnc would be good as well.
I usually select the Format to be DVD compatible, set the audio to be 448, select the Elementary Stream Audio+Video option, then I use the calculator. The audio part is just for calculating final size, since the AVI is soundless.
Im doing a DVD9 AVI, so I select the final size to 8.5GB, and pull the total final desired size to around 8100MB. The VBR 2-pass for a 2 hour movie is around 7800 kbps, and the predicted final size is around 7.5GB.
But when it finishes, the total size varies a lot from source to source (that might depends on movie having more or less action scenes), and is often quite below the predicted size (5.5GB, 6GB, etc), making me waste a lot of space on DVD9. While TMPGEnc Xpress is encoding, it does reserve a file with the size it calculated. But sometimes, the finished M2V even ends up being smaller than source AVI.
Question is: am I losing quality? This doesnt seem to be happening with CBR, and I could set the values to fit a DVD9, and the result seems to follow the original calculated size.
Example from a AVI I just encoded:
- Original AVI: Size: 5.89GB; Bitrate: 6528 kbps
- Predicted Values: Size: 7.5GB; Bitrate: 8313 kbps
- Final M2V: Size: 5.60GB; Bitrate: 6214 kbps
Perhaps this is ok, since the final video can't have a higher bitrate than the source(?)
If someone can clear it up, I'd appreciate![]()
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
MPEG-2 bitrate > 4000 with DVD Xpress DX2?
By miamicanes in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2007, 10:12
