I bought i new 640GB harddrive and insert it to my computer. But the computer refuse to start with the new harddrive, just start for a seconde then dies. If i plug out the harddrive everything works again.
My computer is a P4 3GHZ two years old with a Asus P5VD1-X motherboard and Vikings MPT-400 Poweraggregate. Have had 3*250GB harddrives earlier.
So what do you think, to weak poweraggregate? To weak motherboard? To old BIOS? Something els?
Since the problem seems to be the hard drive, I would try it in another computer and see if it does the same thing. If that's the case then I would take it back to where you bought it and get a replacement.
If it can't get to the BIOS screen, and you have 4 HDDs in this box along with a DVD or such, I would check the wattage of you PSU
What happens if you leave the HDD plugged in IDE/SATA cable, but without the power cable? -
You did not say whether this new drive was and IDE or SATA(including SATA II).
There is often incompatablity issues with IDE drives. Some just do not like being slave drives. But you could put both on 'cable select' to see if that solves it.
I've had 4 hard drives and 2 CD/DVD drives running on a really avg PSU. That should not be the issue. -
DBB3 all new 640 GB hard drives are SATA.
guessing one of two things
BIOS
DOA -
Itīs a SATA2. I tried unplug some of the other drives and now it star up, however the harddrive dosenīt seem to spin up and isnīt find in BIOS! So i donīt realy know whats wrong, maybey either the system canīt handle as big as 640Gb? Or maybe it is a faulty disc?
Is there a way to see if the system has a limit for maximum harddrive capacitet?
Originally Posted by MJA
What does DOA mean? I looked at the BIOS updats and there are some minor updates in the newest BIOS, however nothing concerning bigger harddrives.
Trying to modify .VOB file - why didn't this work?
By brassplyer in forum Authoring (DVD)Replies: 8Last Post: 7th Feb 2011, 23:03 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
hacks for samsung DVD-P191 didn't work..
By anoud9 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Oct 2009, 23:48 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 08:07 -
DV to laptop via firewire? 4200rpm didn't work. Will 5400rpm?
By Colmino in forum Capturing and VCRReplies: 9Last Post: 19th May 2007, 21:46
