I need to take a file and use only the left portion of the file and paste in a different file for the right side of the wave,which freeware editor lets me do this and how do I do it?
I am hoping kristal audio does it as I will be doing most of my work with it
Results 1 to 16 of 16
I am having difficulty getting it to do this can you tell me what step I need to do?I am looking at the tutorials is there one that explains this?
Audacity: Open a stereo track. At the top left of the track window (not the main window) you should see part of the track name and a little down arrow. Click on the name/arrow and select Split Stereo Track. You will now have two mono tracks. Close the one you don't want with the x button at the top left. Open your other audio file (it will open in a second window). Split the stereo tracks if necessary. Copy the track you want to the Copy/Paste buffer. Go back to the first window, paste the track. Click on the name/arrow and select Make Stereo Track.
Another way to do the same thing in Audacity is to use File\Import\Audio to open the second wav file in the same window. Then you can split and delete the unwanted tracks and combine without having to copy/paste.
Buy My Books -
Sound recorder?I doubt it does what I need it toOriginally Posted by SingSing
I don't think sound recorder can do what I need it to do
Thanks anyway -
could you please post instructions on how to do this with sound recorder?
1. Open sound recorder.
2. File Open the last wave file.
3. Edit insert a wave file.
4. Move the cursor to the point that you want to cut.
5. Click edit, and you have the option of "delete before...", and "Delete after..."
6. Click one of the delete button.
7. Do the same for "the other" point.
8. Play back and confirm what you want.
9. "Save as" to the file name you want.
How do you edit VOB files from DVDShrink to mute same audio portions?
By soundoff in forum Newbie / General discussionsReplies: 3Last Post: 11th Mar 2012, 20:58 -
Is there any software that lets you edit 1920 and do green screen or roto
By Onceler2 in forum EditingReplies: 7Last Post: 2nd Oct 2011, 05:08 -
Edit Left OR Right Separately >> AVS4YOU Audio Editor
By mrlewp in forum AudioReplies: 0Last Post: 12th Jan 2011, 22:34 -
Audio Editor Freeware?
By Nitro89 in forum AudioReplies: 7Last Post: 14th Oct 2009, 22:38 -
Good editor? (Freeware)
By chronic777 in forum EditingReplies: 10Last Post: 23rd Jul 2008, 15:22
