Results 1 to 9 of 9
    May 2003
    Peterborough, England
    Now I know this is a video forum, but maybe someone on here can help with this one. I've got a wav file that appears to be missing a header. It was recorded on a Nokia E51 mobile phone (using the voice recorder function) and reached the end of the 1 hour maximum record length rather than being stopped during recording. Consequently, I have a file that is 9.3MB in size but with a duration of 0.0 seconds. The file properties are shown as Bitrate 128kbps, Sample size 16 bit, Channels 1 (Mono), Sample rate 8kHz, Audio format PCM. However, opening it in CoolEdit shows it to have 0.0 seconds duration. I opened it in GSpot and it states that the size is 9.28 MB (or 9,512 KB) but shows a Stat of File is Empty (Zero Length), the stream type is shown as WAV->RIFF "wrapper".
    The file can't be empty surely? Something must be taking up 9.28 MB of disc space, I just need to find it! Anyone got any ideas?
    Try also goldwave.
    Sep 2007
    Europe
    You need to find a audio editor that can load raw audio (SoundForge can $300 ).
    If you load with this option, you'll first get a dialog where you need to set the bitrate, sample size end so on.
    It will always load the file not checking anything so you can play it. If it sounds distorted, you've chosen
    the wrong parameters and have to try again.
    If you found it, there's only a short distortion at the start (the corrupted header) which you can easily trim of.
    You then can save the file in any supported format.
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Try Audacity, and try to Import - Raw Data
    I don't know if it will work, but Audacity is free and worth a try.
    Buy My Books
    May 2003
    I tried the 'Open As' feature in CoolEdit and filled in the bitrate, sample size, etc and still the same. Same with Audacity. A friend has Adobe Audition 1.5, which I understand is the updated version of CoolEdit Pro and I figured that if Soundforge can do it, Audition should be able to too, but still no joy. This is what Audition says about the file properties
    This appears to show that the file is indeed empty? Any more clues?
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Several suggestions, maybe one will work:
    Open the file in a Hex editor, if it's an audio file you should see a load of gibberish, but if it's really "empty", it will all be "00".
    Or, try Besplit with the "fix" option.
    Or, try a conversion app, like BeSweet. Just convert to wave and see what it does.
    Or, try some media players, like VLC.
    Apr 2007
    Hungary
    GoldWave and especially SoX should be able to open any wave file. You may have to play around with the parameters though.
    May 2003
    Tried that and found a load of gibberish. In fact, the header looked much the same as another wav file I tried.
    Tried downloading it got totally confused with how to use it!
    Tried that and it refused to run complaining about a missing dll......
    Tried that and would you believe it, it plays the file! All I did then was start CoolEdit, record the playback from VLC and save it as a new file.
    Brilliant, thanks everyone.
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You have a solution, but a few comments:
    The link should be to a package that includes a GUI, "BeSliced". Drag and drop an audio file into it (just a little icon) and choose the "fix" option.
    Yes, VLC can often play problem files. You can also use it to convert: click File/Wizard and step throught the "Transcoding" setup.
