Hi
I use mencoder to convert my movie to LAVC and I it work nice and I can play on the HTPC
Problem is now that I have buy Argosy HV356T and that can't play FLAC.
(it can play MPEG-1, MPEG-2, DivX 3.11, DivX 4.x, DivX 5.x, Xvid)
So now I have to convert all my movie that I want to play in the Argosy but what is the best and easy way to do that?
Results 1 to 17 of 17
The original is LAVC
I use this code if the movie is widescreen when I want to create my LAVC movie
mencoder moviein -oac mp3lame -lameopts abr:br=128 -ovc lavc -lavcopts vcodec=mpeg4:vhq:v4mv:vqmin=2:aspect=16/9:vbitrate=1422 -vf pp=de,crop=0:0:0:0,scale=700:400 -o movieout.avi
The problem I found is when I use winFF it take a long time to convert the movie.
over 1 hour for every movie I convert. -
lavc is libavcodec...
"moviein"
i mean what is moviein?
in what format?
also mpeg4 in avi?
with flac as audio? in avi???
who has flac as audio for video?
anyway, maybe you could enlighten.
"it take a long time to convert"
speed is relevant.
settings can be changed.
your mencoder setup is fast,
it's also crap."I'll give you five dollars if you let me throw a rock at you" -
moviein mean that is there I set to DVD (vob) or to the file I like to convert (like .ts)
like "mencoder c:\mymovie.ts ........"
When I use this code for mencoder it fast, about 20 min it take to convert to LAVC but like I write before my new mediaplayer (Argosy HV356T) can't play that so I going to convert all my movie from LAVC to Xvid.
Just looking for a good program or howto to add many file to a list and then let it convert all the file to Xvid and Winff look nice but I have not get ffmpeg to work good on my Linux machine yet.
Trying to find a nice frontend to mencoder but I have not have time yet to look so much about that yet.
But like you say
"your mencoder setup is fast,
it's also crap."
When I wrote "it take a long time to convert" I mean when I try winff on my computers it take about 1-2½ hour on each movie (the movie is about 90 min). I know it going to take sometime but so much?? -
man, you're all over the place...
when did linux enter the picture??Originally Posted by Cazz
well in windows they're all crap.Originally Posted by Cazz
i'd probably go with simple mencoder shell gui, at least you can somewhat work around it.
for linux i know not.
ohhhhhhhhhhhhhhhhhhhhOriginally Posted by Cazz
i think i get you know.
you've already converted to lavc mpeg4 from various formats,
but they don't play in your new player.
and you plan to re-encode to xvid.
don't re-encode.
change the fourcc tag.
change it to DX50
here's a tool
http://sarovar.org/projects/gfourcc/
and you can use ffmpeg too.
and when converting with mencoder in future:Code:ffmpeg -i input.avi -vcodec copy -acodec copy -vtag DX50 output.avi
Code:mencoder moviein -oac mp3lame -lameopts abr:br=128 -ovc lavc -lavcopts vcodec=mpeg4:vhq:v4mv:vqmin=2:aspect=16/9:vbitrate=1422 -vf pp=de,crop=0:0:0:0,scale=700:400 -ffourcc DX50 -o movieout.avi
speed is relative.Originally Posted by Cazz
for basic quality though, you need to add trell and mbd 2
tripp"I'll give you five dollars if you let me throw a rock at you" -
Originally Posted by 45trippWell I have a computer that I can have on all the time to convert but it run on Ubuntu, and mencoder or ffmpeg is for both windows or Linux.Originally Posted by 45tripp
YESOriginally Posted by 45tripp
ohh so I maybe dont need to re-encode, just change the fourcc tag to DX50Originally Posted by 45tripp
That is very good news if it works with my new mediaplayer.
That can't take so long time as if I have to re-encode all my files
Going to try when I get home. -
Hi again
I have now a another problem after I change the ffource to DX50 that I need to change the size of the movie to 720x480 (I have now 768x576) but when I use -s 720x480 in the ffmpeg code
it dont change it, it just start and change the vtag to DX50 but nothing more?Code:ffmpeg -i input.avi -vcodec copy -acodec copy -s 720x480 -vtag DX50 output.avi
it's not mine eitherOriginally Posted by Cazz
Operating system always matters.Originally Posted by Cazz
especially if you want to talk guis
probably not.Originally Posted by Cazz
of course not.Originally Posted by Cazz
we're just remuxing while changing the tag.
to change the size you have to re-encode...
are you saying your player has a 720x480 max resolution restriction?
if so, anything over will require re-encoding.
also 720x480??
it's unlikely your player supports dar in avi.
you'll need a square pixel resize.
ahh
and i forgot to mention, you should keep resolution to multiples of 16.
so assuming 16/9 material.
resize to 720x400 or 704x400.
Code:ffmpeg -i input.avi -vcodec mpeg4 -acodec copy -s 720x400 -sws_flags lanczos -qscale 3 -mbd 2 -trellis 1 -vtag DX50 out.avi
well the movie I try now is just 4:3 and not widesceen so I think I have to use 720x544
that's right.
704x528 is even closer
(if you're waiting for confirmation)"I'll give you five dollars if you let me throw a rock at you" -
ohh ok well I can try that too.
After I have use ffmpeg file it get alot bigger, from around 740 Mb to 1.01 Gb
and my mediaplayer still dont want to play but not it dont say anything wrong
I have done two screenprint from two diffrent movie, one that work and one that don't work
Work
Don't work
/Update
If I use this code to create a AVI from one of my recorded DVD it look that it work
Going to try more tomorrowCode:mencoder dvd://1 -dvd-device c:/homemademovie.iso -oac mp3lame -lameopts abr:br=128 -ovc lavc -lavcopts vcodec=mpeg4:vhq:v4mv:vqmin=2:aspect=16/9:vbitrate=1422 -vf pp=de,crop=0:0:0:0,scale=700:400 -ffourcc DX50 -o movieout.avi
but it looks goodOriginally Posted by Cazz
use qscale 3 or 4 or higher for smaller filesize.
it's possible your player is crap.Originally Posted by Cazz
from the specs it should play fine.
the files are largely similar.
nothing really standing out.
there's vbr mp3 audio vs cbr mp3,
but then your later mencoder attempt shouldn't have worked either, if that was the case.
probably the gigabyte mark.
try again under the gigabyte mark
Today I have try again, last time it was late and I did have alot to think about
I have try now to rip a DVD
and it work fine in my mediaplayerCode:mencoder dvd://1 -dvd-device c:/homemademovie.iso -oac mp3lame -lameopts abr:br=128 -ovc lavc -lavcopts vcodec=mpeg4:vhq:v4mv:vqmin=2:vbitrate=1267 -vf pp=de,crop=0:0:0:0,scale=720:548 -ffourcc DX50 -o c:/movieout2.avi
after that I convert a AVI file that have LAVC with this code
and it work toCode:ffmpeg -i c:/,oviein.avi -vcodec mpeg4 -acodec copy -s 720x548 -sws_flags lanczos -qscale 4 -mbd 2 -trellis 1 -vtag DX50 c:/movieout3.avi
and it go quite fast to
so thanks alot all the people that help me, THANKS -
I open this topic because I have a little problem with some of the movie.
Some movie have a very high pich and sound extrem bad and later it dont have any sound, is that normal when I have convert a movie?
Is that any way to fix it and is that any way to find out which movie is bad and which movie is ok??
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 09:31 -
How to create chaptering in MKV or Xvid video file ?
By c1steady in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2010, 11:38 -
Need advice how to create high quality xvid w/ subtitles from DVD
By jbloggs in forum DVD RippingReplies: 7Last Post: 12th Feb 2009, 12:37 -
VP7 to xvid: Is it possible? Is it easy?
By EAO in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2009, 12:38 -
Is there easy way to create Win2k boot disk with command prompt available?
By bevills1 in forum ComputerReplies: 9Last Post: 10th Apr 2008, 11:25
