hi there,
been trying to find a solution for this without any luck yet:
ladies, gents,
I ripped my home dvd video (shot w with a canon, miniDVD-RW recorder) using ROXIO media import v9. The video is imported as mpeg or .mpg
Problem when I playback the imported media in wmp: audio starts in sync then progessively gets out of sync (audio gets faster) as the video progesses...
Playing back in other players has the same problems...
I cannot rip the videos again using another software since I dont keep my old vids. So now I am stuck with a collection of some 30 ripped videos where the audio is out of sync...
Why does this happen in the first place???
How can this be corrected? And which steps do I need to take? I am a newbie so not familiar with video editing.
Hope you can help.
thanks
Closed Thread
First mistake, and quite a biggy. Always keep your originals.I cannot rip the videos again using another software since I dont keep my old vids. So now I am stuck with a collection of some 30 ripped videos where the audio is out of sync...
Second mistake. I would not even install Roxio software on my machines, given a choice.using ROXIO media import v9
Don't know why it happened to you without a whole lot more information. What was the source format - PAL or NTSC ? What format is it now ? The usual causes for audio sync problems are bad format conversion and data corruption.Why does this happen in the first place???
If this is an audio drift then the audio must now be longer or shorter than the video. If this is the case you have to demux the audio, and change the speed at which it plays so that the length of the audio matches the length of the video. Audacity, Audition, Goldwave and Sound Forge can all change the speed of audio. You just have to get it into a suitable format.How can this be corrected?Read my blog here.
I answered here:
https://forum.videohelp.com/topic356941.html#1890562
guns1nger,
- since roxio is not an option for you, which do you recomend?
- source formal was PAL and now PAL as well as you can see; here some info on the ripped dvd now being an mpeg as follows:
General
Complete name : C:\Users\Nils\Videos\Canon Home Video 2006-08\23. MAY08 Home.mpg
Format : MPEG-PS
File size : 1.35 GiB
Duration : 30mn 20s
Overal bit rate : 6349 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Standard
Duration : 30mn 20s
Bit rate mode : Constant
Bit rate : 5652 Kbps
Nominal bit rate : 9400 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4/3
Frame rate : 25.000 fps
Standard : PAL
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.907
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 30mn 18s
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -80ms
Menu
Format : DVD-Video
any more specific clue as to why this happened and how to avoid in future? so are these still the same steps to align the audio? or a better quicker way possible?
ONE topic is enough. Continue in https://forum.videohelp.com/topic356941.html
Audio problems after ripping DVD
By ksimz202 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 02:49 -
Audio out of sync when ripping DVD to hq flv
By SystemlordAnubis in forum DVD RippingReplies: 0Last Post: 12th Jan 2011, 07:13 -
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 15:50 -
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 8th Dec 2009, 00:06 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 11:48
