Hi there
I've recently authored a DVD from two video files using DVD Flick but there are only two chapters; one for each of the source files. Is there a tool that can set chapter points in the authored DVD, or do I have to re-author with a different program that will set the chapter points at author-time?
I've just downloaded PGCEdit and it looks like this might be able to do what I want... if I could just figure out how to do it! I've tried googling, but can't seem to find what I'm looking for; maybe I'm just not searching on the right keywords.
Sláinte
middders
http://club.cdfreaks.com
This may be the long way around it, but...
http://atlas.kennesaw.edu/~dhirschl/video/dvd_chapters_tutorial.html
Darryl -
You're not kiddingOriginally Posted by dphirschler
Thanks for the info, I've bookmarked it for reference. Surely there must be a simpler way to do it though. I'm not bothered about setting the chapters exactly, just want to be able to skip through the DVD quickly if I want to get to a specific point; I usually default to every 5 mins when using FAVC.
Sláinte
midders -
Then just skip the HeadAc3he/Goldwave part and set up chapters for every five minutes in DVDAuthorGUI after you demux it.
Darryl -
All you can do with PGCEdit here is registering of already existing cells as chapters. To do what you want, you need to previously split cells in VOBBlanker. The only tool that would do both operations internally, is DVDRemake (not free but much more user-friendly).Originally Posted by midders
I agree with Alex_ander, that Remake is best and easiest for what you want, all in one.
Only problem will be that you can go through chapters using next button only, but I guess you know that. -
Just redo it in Flick. Did you set it to make chapters under Edit Title-> General? It has a few chapter making options. Time, amount etc.Originally Posted by midders
Free Program For Creating Chapter Points In DVD Video Without Re-encoding?
By bbanderic in forum Authoring (DVD)Replies: 3Last Post: 7th Mar 2010, 10:17 -
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 19:56 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 08:38 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 15:44 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39
