Dear All,
I am bit confused here. Let us say that I have two menus, one main menu which contains button for main movie and another button which takes you to trailer menu. In the trailer menu there are a number of clips, each with its own button.
Now in the main menu, for the movie properties in DVD attributes, I use call vmgm menu 1; as Post Command (see attached image). No problem. It returns to the main menu when the movie is finished. This comes automatically in qdvdauthor. Now in the trailer menu (sub menu), I want that when a clip is finished it should return to the trailer menu, not the main menu. But in qdvduathor, the only option is call vmgm menu 1;. It is manually editable, but I do not know what to write.
If can please point me to the right direction, I would be grateful. I did not post is the qdvdauthor mailing list, is has a very low traffic.
Thanks in advance.
It depends if the trailer menu is in the vmgm domain or in the vts domain. If you could post the author.xml file (as zip) which is created by qdvdauthor, I could probably help you.
You can of cause just try to use the command: call vmgm menu 2;
either it works, or it runs on an error
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Similar to > https://forum.videohelp.com/topic322350.html
Very easy if using pgcedit to fix up nav commands after.
Scenarist- return to specific menu button
By emotionboy in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Feb 2012, 12:13 -
Return to Title - NOT Chapter Menu - HOW?
By jlrm365 in forum Authoring (DVD)Replies: 7Last Post: 13th Mar 2010, 22:15 -
Play All and Return to Same menu Problem
By cassy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2009, 20:14 -
create chapter breaks that return to menu afterwards using PGCedit ?
By spiritgumm in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2009, 10:07 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 11:31
