I got some AVI files and I want to encodeby AVIdemux them so that the output file is without sound. Anyone know how to disable the audio when encoding in AVidemux?
audio=> main track => (drop down menu) audio source => none
you want to re-encode or just remove audio track? re-encode = lose quality when using lossy format
you can also use avimux-gui to remove the audio track without re-encoding
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Avidemux - audio
By avextraxjp in forum Video ConversionReplies: 4Last Post: 5th Sep 2010, 22:29 -
Disable HDMI audio
By dataport in forum DVB / IPTVReplies: 3Last Post: 13th Mar 2010, 18:42 -
Disable HDMI audio
By JOHNINA in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2010, 09:58 -
Can't disable audio normalization?
By ngibbs in forum ffmpegX general discussionReplies: 3Last Post: 28th Apr 2009, 16:18
