I've been using Gordian Knot for dvd to xvid for about a year, but i want to understand it a little more and everyone tells me that AviSynth/vdub is the way to go if you want to under it the most, so i was hoping you guys could give me some good tuts to understand it better and to get me started with AviSynth/vdub.
http://avisynth.org/mediawiki/Main_Page
Memorize everything there. As far as I know there are no tutorials, as such. But, if you've been using Gordian Knot for a year then you should already have a solid background. You can still use GKnot to generate your scripts for you for use in VDub, if you're not quite ready to create your own. -
Study and learn the scripts that GKnot produces. Find out what each command does and then look on-line for plug-ins or scripts that may do the same job better and alter your scripts to match. Also be aware that documentation for AviSynth is available in the install folder on your PC, (if you can't reach the link manono provided). Go slow, make one change at a time and check the results in Vdub. Experiment. Make mistakes and learn to recognize some of the error messages AviSynth throws up.
Buy My Books
Just starting to learn Avisynth, can't open mjpeg avi and others.
By bigstusexy in forum Video ConversionReplies: 34Last Post: 11th May 2014, 17:03 -
Burn in filename like timecode? Avisynth or Vdub?
By Taapo in forum Video ConversionReplies: 6Last Post: 20th Oct 2010, 12:09 -
H264/AVC (.TS) gets outsync when using VDub and AviSynth
By x92 in forum DVB / IPTVReplies: 2Last Post: 30th Aug 2009, 23:03 -
equivalent filters from Vdub to Avisynth
By cd090580 in forum RestorationReplies: 3Last Post: 14th Aug 2008, 14:28 -
Speeding up HDTV to DVD via AVISYNTH & VDub
By thymej in forum Video ConversionReplies: 12Last Post: 26th Oct 2007, 23:57
