All things being equal, it shouldn't make any difference whether the firewire in on-board or a PCI card, but all things aren't equal or you wouldn't be experiencing dropped frames. I did a quick check at Asus (Click Here) and there a ton of bios updates and drivers for that motherboard. I didn't look through them to see if anything addresses this issue, but you should. If you don't find anything there or aren't comfortable updating the bios, then a PCI firewire card might make the difference.
Results 31 to 34 of 34
Buy My Books -
The issue with the hard drive write caching is completely different from, and Totally Unrelated to, the Firewire card. While using a different firewire card may very well affect the capture ability, it will in no way affect hard drive performance.
The dropped frames are most likely a direct result of the write caching problem, lowered drive performance is specifically referenced in the technical explanation of the problem. This issue is very rare, I have only seen it two or three times. A second hard drive, unless it is absolutely identical to the first one, is extremely unlikely to suffer the problem. However, there is quite simply no way to predict this, it's a crap shoot.
Purchasing additional Firewire cards is unlikely to affect this problem and is most likely a waste of money.
A second drive offers multiple benefits and almost always helps to avoid dropped frames. Personally I would recommend an internal simply for economic reasons. Definitely not a USB drive. -
Thank you to both of you,I might update the bios but thats a bit to scary if things went wrong.
When i was talking about a fire wire card i wasn't meaning it might solve the problem,Like you said its got to be hard drive related,I was just seeing once i got another HD would it be any better to have a card,To me i couldn't see if there would be any difference in quality or ?? im happy what comes out when i do my transfer.
O just one thing if i transfer from my pc to my camera then i get no dropped frames,Its just when i do it from my camera to pc -
No, as long as the on-board firewire works, the resulting video will be no different.
Buy My Books
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 18:18 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
