I'm trying to understand which filter to use in handbrake - deinterlace or detelecine - and if detelecine, whether to use VFR.
Is there some way to determine whether a DVD has been interlaced vs telecined?
Look for a scene with movement, then step through the 5 frame sequence. If you see split fields over 5 frames, it is interlace. If you see 3 progressive frames followed by 2 split fields, it is telecine.Originally Posted by xichael
See this thread where I posted a sample sequence of telecine frames near the bottom of the page.
https://forum.videohelp.com/topic284981.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Best tool to determine if DVD is hard telecined
By gminnick in forum DVD RippingReplies: 5Last Post: 4th Apr 2013, 14:14 -
Cleaning up residual combing from hard telecined source
By txporter in forum Video ConversionReplies: 16Last Post: 30th Jul 2010, 16:15 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Does anyone have an idiots guide to converting telecined dvd's please!
By Emanef in forum DVD RippingReplies: 40Last Post: 18th Jan 2009, 22:04 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48
