I've had to uninstall AVG.
Piece of shit kept breaking Goldwave, even after I told it to ignore the so-called "virus". For the record, it was a false alarm, Goldwave is fine, and I've had it installed for about 4 years now.
Goodbye and good riddance AVG.
I need Goldwave far more than I need AVG.
Results 1 to 10 of 10
Must be past my bedtime, but the first time I read your post, I thought you dumped AVG 4 years ago and were now just posting about it.
Good night
I stopped recommending avg years ago.worthless when it comes to healing infected pc's (not in your case Lord
NOD32 nothing else .it was selling at newegg.com for $14.99 Free Shipping few weeks ago -
I got tired of all the AVG 'false positives' and switched to Avast.
Though I have heard the newer AVG 8 is a bit better with that problem.
I'm going to use Avira on this system, see how that goes for a while.
I read some complains about "Pop ups" and "Annoying nag screen "Originally Posted by lordsmurf
It pops up every time it updates offering you the choice to upgrade to the full program.The price is reasonable for what is a good a/v but if you don't like the pop up you could always disable it.
http://www.elitekiller.com/files/disable_antivir_nag.htm -
Yeah, thanks. I was wondering how to do it under XP... someone once mentioned you could do it by mucking with the security settings, but wouldn't say how.
The popup doesn't really bother me, as it only shows up when I'm updating, and I manually update it (though still frequently)... but it does bother my relatives. I don't trust their ability to remember to manually update, so...
If cameras add ten pounds, why would people want to eat them? -
Why don't you get the one and only real antivirus (NOD32)?Originally Posted by lordsmurf
At least give it a free trial, see for yourself the difference, somehow Im positive it will find at least few things AVG missed on your system
(if you need any tips how to set up NOD *perfectly* just PM me)
anti-virus
By Willy5157 in forum ComputerReplies: 19Last Post: 14th Dec 2011, 09:13 -
Do you use Norton anti-virus or freeware of something else?
By beavereater in forum ComputerReplies: 26Last Post: 31st Jan 2011, 22:34 -
AVG Virus warning on this Website
By wulf109 in forum FeedbackReplies: 59Last Post: 20th Jun 2010, 11:16 -
Free Anti-Virus Opinions
By HotDamn! in forum ComputerReplies: 19Last Post: 13th Jan 2010, 15:49 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 21:28
