Looking for a Win XP util (or a set of utils combined into one) that possibly does all of the following things:
1) connects to my DV camcorder and receives the incoming DV stream via firewire (like most standard DV capturing programs)
2) Allows me to choose a compressor such as XVID, for instance, to set the quality of the output file.
3) Can re-compress 1) to 2) on the fly (e.g., the way WMM does things: DV->WMV).
4) Reports if any frames were dropped (the way DVIO.exe does).
If no such app exists, is there any way to setup something like GraphEdit to accomplish any of this?
I would like to stop using WMM for capturing DV footage in compressed form (WMV), but I can't find a suitable substitute.
WMV is generally fine, but there are a number of issues with that format, as well as the fact that it sometimes appears to drop frames, resulting in missing footage.
Thanks.
A Pentium M 1.8 is probably too weak to do xvid encoding real time.
http://www.kiva.org/about -
Ok, Thanks.
So, WMM manages just fine (2.1 MBps CBR setting), although, granted, it does ride my CPU rather heavily.
Is there something else, perhaps, that's of comparable quality (doesn't have to be XVID necessarily), but is AVI based, so I can edit in VirtualDub, if necessary?
Min DV capture, with auto scene file splitting on the fly
By Hitmandj in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2011, 18:40 -
good free DV (firewire) capture app with on the fly conversion
By a1s2d3f4 in forum Capturing and VCRReplies: 33Last Post: 14th Nov 2010, 13:31 -
Firewire capture - Encode on the fly?
By BruceLEET in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 18:45 -
BlackMagic - On the Fly Analog Capture - h264 Convertor
By Soopafresh in forum Latest Video NewsReplies: 4Last Post: 29th Apr 2008, 00:22 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 10:48
