    Sep 2008
    Australia
    I kind of like these two tools very much but am having a small issue as my needs have grown .
    I convert my vob to .m2v + .ac3 format using dvd decrypter.
    then i pull these files in cuttermaran to edit the video.
    my problem is I am unable to hear the sound while doing the cutter maran cuts/edits. but the final cut video (mpg muxed with Imago addin cuttermaran ) is perfectly fine
    to confirm the problem is with the ac3 file i convert the ac3 to mp2 or mp3 using besweet and then feed the mp2/mp3 file to cuttermaran. i can hear the sound now while cutting/editing but alas the av synch problems surface when doing this
    this has been happening for a long time , but now i have a need to hear the sound to edit the video accurately . or else i am left with creating the cut video and then having a look at it and then going back again to cuttermaran to fix it , which is a bit tedious to say the least.
    would appreciate if u could provide the solution using these two tools or point out what i am doing wrong.
    this happens for all vob files created by my sony 703e dvd handcam
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You could try installing this:
    https://www.videohelp.com/tools/AC3_ACM_Decompressor
    I did this trick many years ago for....well....forget which software.
    Sep 2008
    Australia
    i tried that .. downloaded it and ran the inf file to install it . no luck still.
    is there a way of making cuttermaran/tmpgenc to force to use this codec
    Sep 2008
    Australia
    lazy me ... i just installed the ac3 filter on my pc ... and problems solved .. thanks hech anyway .... ur suggestion got my lazy brain working at last ...
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I think i did the same exact thing too....installing one....then installing the other.
    Glad it worked out.
