I ripped a DVD into my hard drive and now I would like to make a DVD, I've got vob, ifo and bup files, what software should I use and how do I do it? Any tutorials on it?
	The guides are to the left<<<<<<<Originally Posted by webdude3
	What size are the files? If more than 4.37GB, they won't fit on a regular DVD-5. DVD Shrink can reduce them. Or use a Dual Layer DVD disc. And use ImgBurn to burn to DVD. All freeware.
 If you want to know what those VOB, IFO, and BUP files are, and find out more about the DVD format, specification and structure, look to 'WHAT IS' DVD to the upper left on this page.
 And welcome to our forums.
	I've got DVD-5 but the files are not even 4GB. It looks like a very good tool but I'm getting an I/O Error about half way of the burn. I don't know what is causing that, I tried with two DVD-R already so I doubt it's the disk.Originally Posted by redwudz
	ImgBurn creates a log file. You can post that here or look to it for the cause of the problem. But my guess is that there is a problem with the file itself. If that was a newer commercial DVD you ripped, they have some advanced protection and a program like DVDFab HD Decrypter may be needed. If it's a non-commercial DVD then there may be other problems.
	I got it working now, after some googling I found out that the firmware for DVDRW needed to be upgraded and that solved the problem.
  DVD player to connect to a PC hard drive, or a networked hard drive?By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40
  Sony Vaio with partitioned hard drive(Want full hard drive space on C)By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42
  Need Help! Can't get my DVD to burn from my hard drive!!!!By kallimac in forum Newbie / General discussionsReplies: 3Last Post: 29th Jan 2010, 12:53
  movies on Hard drive fail to to burnBy dymx in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Apr 2009, 05:53
  New DVD hangs; copied to hard drive with IsoBuster but cant burnBy bernie01 in forum DVD RippingReplies: 5Last Post: 1st Aug 2007, 17:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
