Firstly are disc made on a set top box what is refered to as an episode disk?
What the best and free software to rip them (I think I have th econver bit sorted ok) - remember discs on a set-top-box have no extra sorts of protection
In my opinion....you need to do a LOT of reading before you go farther.
FIRST....it doesn't matter of your discs are protected or not....most of the software I think you are overlooking (as only for protected discs) also work perfectly well with DVD Recorder discs...DVDDecrypter is a prime example.
SECOND....I never heard of an episode disc. That must be something you read in the manual for your DVD recorder. Forget that word....it means nothing here. -
Yep you can use anything to rip a homemade disc. Even the old non-updated dvd shrink will work just fine (it will make a perfect copy of a single layer disc or even a dual layer disc if you tell it to - however MOST settop recorders are single layer only - though a few dual layer recorders were made).
You could choose to extract a single show or the entire disc. Then you can re-edit them however you want to.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Found this http://handbrake.fr/ and is does convertions as well so I can make stuff straight for my psp
I tried searching for 'open source dvd ripper' instead of 'free dvd ripper' and that came up first hit.
Is there a way to control a TV set top box over a LAN?
By True Colors in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2011, 13:00 -
FCC allows blocking of set-top box outputs
By joepic in forum Latest Video NewsReplies: 30Last Post: 30th May 2010, 11:03 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 13:48 -
HD Set Top Box- Teething Issues...
By bettytron in forum DVB / IPTVReplies: 2Last Post: 30th Dec 2008, 03:32 -
Recording digital tv via a set top box
By rapattack in forum DVB / IPTVReplies: 4Last Post: 16th May 2008, 10:28
