Hi. I downloaded the Apple Special Event, September 2008 podcast via iTunes. I want to convert the video into an xvid so that I can watch it on my DivX dvd player as I don't have an AppleTV. I tried using ffmpegX but it doesn't work. DivX Converter won't support the source video codec. How do I go about doing this on my mac?
	http://www.pcpodcast.org (Website Under Construction)
	MPeg streamclip?
 And moving you to our mac section.
	Also try converting to anything else (DV, for example) from within QT Player Pro (assuming you've paid for the "Pro" upgrade). If the stream is protected, it will tell you that immediately and won't let you convert. That would explain the failure of ffmpegX, as well.
 But do try MPEG Streamclip (as suggested by Baldrick). Free is good.
	MPEG Streamclip did the job
 thanks heaps.http://www.pcpodcast.org (Website Under Construction)
  Question about settings for convert movies in divx/xvid to m4v or mp4By Marcelo_Ramone in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2011, 10:25
  How to create M4V files w/AC3+AAC from M4V w/AC3 only??By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 17:15
  Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25
  How Can I convert avi(xvid) to ipod tv out (H.264)?By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 11:27
  Syncing .m4v and AAC files in flash playerBy Pureweb in forum Video Streaming DownloadingReplies: 0Last Post: 13th Aug 2008, 11:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
