What doesn't this card record? Just acquired 1000+ beta/vhs tapes and would like to use this with a Super Betamax machine. Seems like the easiest device to use. What formats does it record in? DIVX,AVI? Want to be able to put the finished product on to my external drive and play them on my PHillips. Any known problems with macrovision?
Well if the device supports composite and/or svideo inputs than it will be able to capture from any source that utilizes those outputs.
You'd have to check the specs on the package and/or website for specifics. Every device is different. Most should be able to capture via software to mpeg2 for dvd recording - at lease if it touts the ability to transfer to dvd that is.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum Capturing and VCRReplies: 4Last Post: 21st Nov 2010, 22:22 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 20:51 -
By Codifexda1st in forum MacReplies: 1Last Post: 24th Feb 2010, 21:28 -
Easycap Video Grabber audio problems only right side
By laslim in forum Capturing and VCRReplies: 1Last Post: 12th Oct 2008, 03:47
