I have been trying to convert a wmv file (which I have deleted from frustration) to avi (xvid) using avisynth. The wmv file had audio properties of 44100k for a sample rate and a bit rate of 128kbps. The frame rate (taken from FitCD) read as 25fps I dont remember the exact codec but it was WMVx (with a number for x). I took the script that FitCD gave me and (leaving the PAL box checked) imported it into Virtualdubmod, extracted the audio as an uncompressed PCM wav file, Then encoded it as an mp3, keeping the same sample rate of 44100k and the same bit rate of 128kbps. In Virtualdubmod, used the xvid as the compression codec, keeping the same frame rate of 25fps, then I added the mp3 into the streams list, and deleted the original mp3 audio stream, After all finished processing I would listen to the new avi and the audio would be out of sync (although it is in sync as an wmv file, prior to any processing). Why is the audio file out of sync?
Seek, And You Shall Find.
Thanks Jagabo, I will try your script and post back.
EDIT>9/22/08> GMT5 10:37pm
Worked perfectly! Thank You Much JagaboSeek, And You Shall Find.
How to convert from avi without loss of audio-video sync?
By bonespur in forum MacReplies: 6Last Post: 26th Feb 2011, 21:47 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
trying to convert avi w/ dolby ac3 audio and it wont sync right
By cduval04 in forum Video ConversionReplies: 2Last Post: 14th Jan 2009, 19:40 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 19:45 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 09:48
