Is it possible to decode a DVD player from Region 4(Australia) to a regionOriginally Posted by kitty
free Dvd player? If yes, how to do it?
I moved your post from our Glossary Forum. It's just for definitions, not questions.
What player are you asking about? Some have hacks to make them region free. Some don't. The hacks may have several ways to implement, again depending on the player.
We have a 'DVD Hacks' page to the left. <<< You may be able to find your player there and some info for modifiying it.
And welcome to our forums.
Note that all players cannot be hacked and if you have a player that cannot be hacked, you are simply out of luck here. Hardware changes by the manufacturer during production may break hacks that used to work.
Worst case, you can rip a DVD to your hard drive and burn it to a new DVD. Ripping removes region coding from the disc. -
Some of the foreign DVDs I buy do not have a domestic counterpart available, and so I'm stuck with several region 2 and 3 DVDs in a region 1 country (US). Instead of worrying about hacking the player, I simply back up each foreign DVD I own to a region-free DVD-R using DVDFabHDDecrypter. This is probably the only solution when there is no region hack to a specific player. Otherwise, you can always buy a region-free unit. It costs a bit more, but not an outrageous amount more.
Many Philips and cheap chinese players can be hacked via the remote, I see sellers selling region free Philips machines that take me 60 seconds to make region free myself.
There is no need to pay more unless you really want a specific model.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Samsung HT-X810 region change
By s63283 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 3rd Nov 2009, 10:45 -
cannot change region code from 1 to 2
By decocal in forum Software PlayingReplies: 6Last Post: 16th Oct 2009, 04:27 -
Can't change region code
By The-One in forum Blu-ray RippingReplies: 0Last Post: 22nd Mar 2009, 11:19 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 21:58 -
how do i change region on sanyo sL40?
By magsbb in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Aug 2008, 03:54
