Hi i don't know whats causing this problem, i right click to install and everything seems to install fine, but when i open up virtualDub Mod it isn't showing up for selection.
The only thing thats changed since it last worked was instead of using windows xp x86 version im using windows xp 64bit version.
Results 1 to 11 of 11
here's a thread with some things to try
https://www.videohelp.com/forum/archive/virtualdub-lame-mp3-encoder-option-missing-t307670.html -
went through all them steps, and also tried many different versions of lame, and no luck.
but when looking in audio properties / audio codecs / lame shows up but cant be enabled as shown on the picture.
everytime i enable it and go back, its the same again. -
did you try re-installing lame 3.98 or using the un-register / register bat in the zip file?
might need to reboot after the install for the codec to show up. -
3.98 lists xp64 and vista64 in it's ok os's. i've never run across a separate 64 bit version.
Only guessing, but do you have other MP3 encoders on your system? You may have a conflict. LAME is fairly basic. I've never had any problems installing the ACM version of it for use in VD on several systems.
MP3 (LAME) in Avidemux
By moiz in forum AudioReplies: 2Last Post: 18th Feb 2012, 10:18 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13 -
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 03:12 -
MP3/LAME and H264/X264
By Xavier in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2008, 22:53 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 08:16
