Hey,
I have an .AVI which I need to re-sync. It goes out of sync around hafl way through and does not fix it self.
Are there any quick/easy/free tool/s to fix this issue?
I can also encode it to .WMV if there is a better tool for fixing sync in .WMV format.
Thanks!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I use VirtualDub and/or AviDemux for my sync issues....but you may have something a bit harder to cure if the sync issue starts half way through.
What are you playing it on? PC? Standalone DVD player?
If it's a standalone DVD player AND your audio is VBR (variable bit rate) MP3, then converting the audio to CBR (constant bit rate) MP3 and using VirtualDubMod to mux the new audio file in should fix the problem. If you are playing on a PC or your audio is something other than VBR MP3, then your sync issue will be very difficult and very time consuming to fix, if you can fix it at all. -
Hi thanks for the fast responses.
The files are played back on PC and the audio is CBR.
So if it is CBR audio this makes life easier to fix? -
Originally Posted by silmarallion
VBR sync issues are quite common. When you have CBR audio, that means that you can't blame VBR for the problem, so there is no quick fix. If you can fix it all, it will not be easy. A quick way to try to fix it would be to shrink or expand the audio by a certain amount (assuming you can figure out that amount) but such work may just introduce other sync problems elsewhere. The only thing that probably would really work would be really labor intensive, where you chop up the AVI file into a bunch of smaller pieces, fix the sync in each piece, and then put all the pieces back together. -
Here's a longish thread I found that might be of some help to you, but no guarantees. Sync issues are a real bitch to fix.
https://forum.videohelp.com/topic316884.html -
thanks for the help guys, will look into the other thread and see if that helps any. looks like I'll have to give this one problematic file up, but this will be helpful for the future!
thanks again!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
