As a newbie I need some advice for a video conversion and editing project.
I have one long VOB file that I wish to convert, split accurately(!) (to get correct parts), re-join, add titles, add logo (visible permanently), add music, perhaps reconvert.
I then wish to add this file to my website, to Youtube, and to be able to email the file. Note that I see this as being 2 or 3 different output files.
1) A good quality uploaded to my website
2) Perhaps the same file upped to Youtube (let them do the conversions of quality and size)
3) A smaller file to email.
I am trying to research methods and choices to be made to do this as easily as possible.
Three questions:
1) I have started by converting to avi and have found that I cannot accurately split the file - problems with keyframes... So I figured if I convert to some other format (from the VOB) it may be possible...?? Can someone advise? EDIT: apparently H.264 is probablematic when splitting - is that correct? Which would be the best codecs to use?
2) I also figured that the file files should be in flash format...? Again any advice would be cool..
3) And if anyone (someone...anyone...help...arghhhhh!) could subjectively(!) suggest the best software to use for each stage would be good - probably the simplest that will do just the job required, I really don't want to have to learn how to use flash or premiere unless really necessary.
EDIT: I have been looking at VirtualDub and Avidemux..is that the way to go? How can I add some logos and titles?
Free beer tomorrow for anyone that can give me pointers...
Cheers
Grant
Advice on File Formats and TBC for 8mm & VHS
By mrees in forum RestorationReplies: 15Last Post: 19th Jun 2011, 21:52 -
Splitting and joining different content and video formats with new audio
By shrinkage in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2009, 11:17 -
Connecting Freeview to Panasonic DMR-HS2 Advice Required!
By wilberfork in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Aug 2008, 07:23 -
Convert AVI to DVD best method advice required please
By vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 10:01 -
Software Required
By dbanga in forum ProgrammingReplies: 2Last Post: 15th Jun 2007, 06:47
