A shout out to all ConvertXtoDVD and Audio Guru's please...
Okay I have a number of MKV videos with similar specs to that below:
Code:PlayTime : 1h 17mn Bit rate : 540 Kbps Encoded date : UTC 2008-09-11 15:04:16 Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video #0 Codec : MPEG-4 AVC Codec/Info : MPEG4 ISO advanced profile PlayTime : 1h 17mn Width : 640 pixels Height : 272 pixels Display Aspect ratio : 2.35 Frame rate : 25.000 fps Language : English Audio #0 Codec : A_AAC Channel(s) : 2 channels Sampling rate : 48 KHz
Now, this is a .mkv container as mentioned and uses Nero AAC audio when it was encoded from AVI -> MKV
When I load into ConvertXtoDVD it does not have an Audio Stream, it only has the video. If I do a conversion the Video ends up playing fine on a standalone DVD Player, but of course no audio
Is there some sort of codec I am missing or something? The videos play fine with Sound in Media Player Classic.
A Solution to this problem would be greatly appreciated.
Cheers.
[size=9]Zhare Your Info Article Publisher
R5DVD.com Support Team
VLCPlayer.info - My Favourite Media Player -
You can try using XVID4PSP as it can go from MKV to PAL DVD or NTSC DVD and has a fairly simple-to-use interface while still managing to be pretty much full featured. Plus it will work with AAC audio.
Both ConvertXtoDVD v2 and v3 work with aac audio in .mkv containers
Do you mean you can't see the audio track in the tree menu when you load it?
There might be something bizarre with your file; e.g. either the way you encoded the audio or the container.
Maybe try replacing the container to .mp4 with YAMB
Or perhaps your install got corrupted, try reinstalling
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19 -
ConvertXToDVD, FFMpeg and AAC LC Audio
By Maikeru-sama in forum Authoring (DVD)Replies: 1Last Post: 10th May 2008, 20:28
