Hi,
I did successfully rip a small scene which I know was at the begining of a dvd with smart ripper (guessing the .vob file)-->dvd2avi-->save as .d2v and openend in tmpgenc and code to mpeg2.
Is there a way to see what I want on dvd and see clearly the referenced .vob to rip and than edit with dvd2avi?
Specifically, I'm looking for the transition scene in austin powers where he says 'Yea Baby'![]()
thanks,
Jack
Play your DVD on a software or hardware player and take note of the chapter number.
Then, use Smartripper to rip the appropriate chapter. Convert to uncompressed AVI (or with HuffyUV) and then select the in and out points and convert to MPEG.
Regards.Michael Tam
w: Morsels of Evidence -
Alternatively, you can rip a clip of any size, from one frame to a whole DVD, using the nifty DVDx 1.6
http://www2.labdv.com/dvdx/download.phpAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
How to rip dvd into small size mkv
By mazeer in forum DVD RippingReplies: 5Last Post: 5th Jan 2011, 15:05 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
How to copy a video segment from my DVD-Camcorder
By dark_cyber in forum EditingReplies: 6Last Post: 15th Oct 2008, 02:20 -
convert DVD segment to slow-motion video
By jackieO in forum Video ConversionReplies: 2Last Post: 7th Oct 2007, 15:36 -
Small Quicktime Clips in a Premiere Pro Project
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2007, 22:27
