The quality of an authored DVD and DivX/Xvid of the same video looks the same to me when I play it on my DVD player.
So is there any advantage(s) to authoring if the player can play DivX/Xvid?
	It depends on the source. Do you mean Blu-ray/HD-DVD => DVD or DVD=>DVD or DVD=>AVI ?
 It depends on the XviD settings. If you use high bitrate (or quantizer) / good quality settings it might be difficult to tell the quality difference. You might be only able to tell on a frame by frame analysis
 Menus, extras on an authored DVD, not on XviD
	What sort of TV and player are you using to compare the two ?
 Newer and larger TVs are more likely to show up the differences and inherent flaws in most Divx files better than an older CRT screen. Things that look OK today might not look so good tomorrow.Read my blog here.
	If your source file is DivX and your player can play it, converting it to MPEG2 (DVD) will only lower the quality. Likewise starting from a DVD you'll take a hit going to DivX. Only you can tell how bad a hit it is.
  My DivX DVD Player can't play my avi DivX/xvid videoBy Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11
  Would synch mostly occur on DVD to DivX, or XviD to DivX?By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01
  Weird I don't have XviD or DivX codec installed but I can see Xvid moviesBy Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
  DivX/Xvid/Whatever to DVDBy FallenAngelII in forum Authoring (DVD)Replies: 4Last Post: 12th Dec 2007, 18:04
  DVD vs XviD vs DivX ?By richbell in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2007, 07:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
