    Feb 2006
    I was trying to burn some AVI files using DVD Flick, and it didn't burn my disc after it encoded the files. How do you change if you are using a DL disc DVD-9? Are there any easy manuels on this program? Thank you in advance.
    Dec 2004
    Triptonia
    project settings->general->target size->dvd-dl
    project settings-> burning
    set burning options.
    how about the button in the program that says: 'Guide'?
    "I'll give you five dollars if you let me throw a rock at you"
